Need help
Old May 4, 2019 | 03:57 PM
Jason899's Avatar
Default Need help
So I’m working on My 1996 Honda Civic DX errer code P 1509 which is the IAC. So I replaced the control module that took care of that I don’t that goes up and down. But now It idles too high just under 1100 rpm’s so will not pass smog they said it was an internal vacuum leak everything else looks good and externally. The other Eric code says valve stuck or not opening on the way for the IAC. But there’s a brand new part on there. So where do I go next? To diagnose this
Old May 4, 2019 | 06:53 PM
Recheck IAC for proper operation
Check the throttle cable, sometimes if it is in the wrong position due to work done under the hood (it can make the idle run high)
Old May 7, 2019 | 07:38 PM
You might also try some throttle body cleaner ,not carb cleaner ,throttle body cleaner. Could be gummed up a little
Hapkidokid
Oct 28, 2013 08:35 PM
ronzdad
Nov 18, 2010 12:57 PM
bdunk881
Apr 20, 2010 12:00 PM
ryanmcde
Feb 26, 2009 08:43 PM
Darkmyst
Oct 5, 2008 09:27 AM
