Not a main relay lol
Old May 27, 2021 | 09:08 PM
Jacob skaggs's Avatar
Default Not a main relay lol
Hi I have a 89 crx si that sat for 7 years ran great when we parked it. It will start and die the main relay is kicking on and off like it should i can here the fuel pump i can Bairly keep it running if i pump the gas real fast I have cleaned the gas tank and all fuel lines replaced fuel filter pulled injectors and watched them all fire like they should I have also replaced the distributor plugs and wores no help any advice
Old May 28, 2021 | 12:17 AM
welcome to the fourm. remove your fuel line after the pump and turn the engine to see if you have fuel pumping out. these older crx after sitting a long while seem to have their pump fail. https://www.reference.com/world-view...49388a9326285d
Old May 28, 2021 | 07:43 AM
So i have had the fuel line off the rail after cleaning the fuel system and it did pump fuel out i am going to try and get a fuel pressure gauge on it today to see where it is sitting its acting like a main relay issue but that is all working properly
Jennifer Morgan
Jul 13, 2013 02:43 PM
~91crxsi~
Apr 6, 2011 07:04 AM
lp284
Nov 8, 2010 12:36 AM
nathan.chase
Nov 29, 2009 12:07 AM
stegmo2
Aug 29, 2007 08:19 AM
