P0420 code on 2000 civic, already replaced cat & o2 sensor
Old Jan 8, 2021 | 04:52 PM
danmurphymn's Avatar
Default P0420 code on 2000 civic, already replaced cat & o2 sensor
Hey all, I'm chasing down a problem on my daughters 2000 civic.
We've had it for a year and a half or so. Initially I replaced the exhaust manifold & catalytic converter & o2 sensor cause the manifold was cracked and it was throwing a P0420 code. It also didn't want to start in the cold.
I ended up putting new plugs & wires in it also. Well... it's cold in MN again and it's doing the same thing.
All of my research for P0420 says to replace the cat and/or o2 sensor which I did just over a year ago. What thoughts do any of you have???
Old Jan 8, 2021 | 08:52 PM
welcome to the forum.. you wrote that you did change a O2 sensor, there are 2 ea. also must be Honda sensor no after market even if aftermarket is same make. check wiring, check timing, and eng temp sensor may cause code P0420
Old Jan 8, 2021 | 10:50 PM
On Honda vehicles, there are two O2 sensors for each bank
One is up stream and is a air fuel ratio sensor type
The other is downstream and is the one that checks the efficiency
ACmech52 is right. Honda vehicles are sensitive and need Honda OEM O2 sensors.
If you have Honda sensors and still have P0420 then might want to check the wiring.
The next thing to do is to put injector cleaner in the gas.
Some people use stuff like Cataclean to try to clean the cat.
Don't know if it really works.
Mjkearns
Aug 12, 2020 03:45 PM
scanner737
Nov 10, 2017 12:56 PM
Ben
Apr 3, 2007 04:44 AM
1998HondaCivic
Jan 20, 2006 02:13 AM
