quick camshaft question
Old 05-25-2008, 01:05 AM
dahuckman15's Avatar
Member
Default quick camshaft question
Ok i finally understand what the markings on aftermarket camgears mean. Now how do the camshafts line up with the camgears? are there markings on the camshafts that line up with the camgears? any info is appreciated much!
Old 05-25-2008, 04:46 PM
Default RE: quick camshaft question
cam gear has key way, cam shaft has key way slot, alighn, install keyway, install bolt to hold cam on to cam shaft.
Old 05-25-2008, 05:30 PM
Member
thank you so much for the info. i've been trying to find all the info i need to learn timing and replace the camshafts and it's taken a while. if i replace the camshafts would i need to replace the valves? i know i need to upgrade the springs and retainers though. plus on http://www.skunk2.com/installation/305-05-5145.pdf it show's what measurements need to be taken after the camshafts are in place. how do i measure the valve lash, and what do the other measurements mean under other recommended camshaft specifications?
JayB
11-01-2013 08:52 AM
Shpook
05-26-2009 12:04 AM
7Health
04-30-2008 10:03 PM
jfg
04-01-2007 04:20 PM
treydawg00
02-24-2006 08:40 PM
Quick Reply: quick camshaft question
