starting/idle problems
Old Jun 8, 2013 | 09:50 AM
Anthony William Garcia-Wolff's Avatar
Default starting/idle problems
So I have a 1990 Honda civic lx with the D15 motor. My first issue is at any given random time the car will not shut off but the check engine light will come on and lose power. When I turn the key over and crank it the motor turns over but it doesn't start back up. After I let it sit for bout 10-15 minutes give or take then it will start back up and run fine.
The next thing that is wrong is an idle issue, the car idles around 1500 rpms and then when at a complete stop it will start going down then rev back up. A co-worker of mine has a hatchback new year then mine but his was doing the same thing.
If someone can please help me with these issues that would be greatly appreciated, I need my car to be running cause it's the only mode of transportation I have and I'm trying to go to school for automotive. Thank you
Old Jun 8, 2013 | 10:15 AM
welcome to the forum. when your car idles fast and after its warmed up and idle goes up and down, clean your egr valve, may be sticking or very carboned up.
for no start after warm and shut down, could be your master relay.
no shut down after key shut off may be caused by your ignition switch.
Old Jun 24, 2013 | 04:09 AM
Dhola Sajan's Avatar
hey all thanks for all the info guys but it didn't work and i also did the same thing on my si but now my si has idle problems? i cleaned the iacv and the throttle body and now my si has idling issues im stumped any other suggestions?
What Can You Do With Your Old Car?
Old Jun 28, 2013 | 12:43 AM
slammed94eg's Avatar
please explain the way it idles.. Is it rough? High? Jumpy??
Old Jun 28, 2013 | 12:46 AM
idle can be a bunch of things, such as a coolant problem, a vaccume leak, iac, fitv things like that. try checking if all vaccume hoses r in correct spits no leaks and as well check intake manifold gasket
PROJECTHONDA
Jun 11, 2007 11:44 PM
andy_1977
Jan 14, 2007 03:04 PM
briansforeman
Jan 14, 2007 03:03 PM
briansforeman
Jan 2, 2007 12:53 AM
arpiegee
Nov 24, 2006 10:49 PM
