throttle cable help
Old Oct 11, 2013 | 12:12 PM
Hapkidokid's Avatar
Default throttle cable help
hi,, I have a quick question reguarding the throttle cable, when I drive my brothers cars that are older (1994) the gas pedal doesn't seem to be as sensitive as his,, like its almost like stiffer to press as to where his u barely touch it and it.. can anyone explain this and if theres a way to fix it so my gas pedal is more sensitive and my throttle response is better
Old Oct 26, 2013 | 09:05 PM
lowlife9's Avatar
they have devices to lubricate throttle cables otherwise replacing the cable works best but thats a pain in the *** to do yourself. you can also try getting under the dash and spraying the gas pedal with a de-graeser cleaning it then applying some white lithium grease. you can also try spraying some white lithium grease into the cable itself while you have somebody pump the gas pedal but that's really only a band-aid for the problem.
Old Oct 27, 2013 | 03:16 AM
Also after trying the suggestions lowlife mentioned buy some throttle body cleaner and spray it down good,my wife's Accord sometimes sticks slightly and it helps.buy throttle body spray not carb cleaner.
Old Oct 28, 2013 | 08:35 PM
JBays2011's Avatar
possibly you have slack in the cable too ...some throttle cables can be adjusted
DrDenby
Jul 11, 2015 04:46 AM
Meals
Sep 9, 2008 07:21 PM
ALLRED27
Aug 19, 2008 09:03 PM
High V3l0c1ty
Nov 20, 2006 01:18 AM
High V3l0c1ty
Oct 18, 2006 09:53 PM
