trouble with engine identification
Old Sep 19, 2008 | 02:30 AM
evidentloss's Avatar
Default trouble with engine identification
i have a 99 civic ex which i know comes with a d16y8 vtec but i dont have a vtec head and i was told that my engine wasn't a d16y8 how do i find out for myself it says d16y7 on the camshaft pulley. is that it? and what all would i need to make it a true vtec?
Old Sep 19, 2008 | 05:07 AM
Default RE: trouble with engine identification
welcome to the forum, check your engine block, it should say d16y8, also check next to your distributor and see if there is solenoid next/around it. if all the above are there, the 99 ex in the us came with a vtec engine/head. 127hp. This is if it a stock us made civic.
Old Sep 19, 2008 | 05:45 AM
only thing i can find on the block is d79021026l
Old Sep 19, 2008 | 05:51 AM
no i found it. it was covered with gunk. it's a d16y7 which is from an older car and illegal. oops. swap is in order.
Old Sep 19, 2008 | 05:55 AM
if i got a d16 vtec head and a vtec controller would i need anything else to make it a true vtec? and thank you for your time and any help you have.
Old Sep 19, 2008 | 08:40 AM
your current engine is found in the 96-00 dx/vp/lx/cxhatch, compression is 9.4:1 106hp if you want a vtec, best to find the whole engine and the ecu that comes with it. now you have 127hp. may cost less.
HondaJohn
Aug 15, 2012 10:58 AM
honda_lover92
Jan 18, 2012 11:30 AM
captmoto
Sep 4, 2010 10:45 AM
accorddude14
Nov 3, 2009 10:59 AM
hatchbackbaby
Mar 16, 2008 11:28 AM
