vtec swap
Old Jul 20, 2010 | 04:19 PM
nvision's Avatar
Default vtec swap
I own a 2003 civic lx with a d17a1 non-vtec and i would like to swap it over to a d17a2 vtec what parts other than heads and intake manifold do i need to acomplish this?
Old Aug 3, 2010 | 09:28 PM
94_sol_vtec's Avatar
Default what you need from a non vtec to a vtec
i have done this to my 88 prelude from a b21A1 non vtec to a JDM H22A vtec.
if you are just doing the engine only by yourself, then there not alot you need. ceause there both d series motor and same mounting in the engine bay area.
what you need is a :
-your generation civic d17a2 vtec engine
- 2003 civic d17a2 vtec engine wire harness or you could repin your enine harness into a vtec harness. (note: it a pain in the rear to repin your engine harness to a vtec harness, took me 6 month to get my resource and repin my engine harness. best recommend is to get a d17a2 vtec engine harness, save the trouble.)
- d17a2 vtec ecu (if run a non vtec ecu, engine run poor)
- exhaust manifold - you could reuse your complete exhuast maifold system
- intake manifold - use the one on the d17a2 vtec motor (you need the vtec accessory sensor on the intake manifold)
- a mechanic person with basic engine swap knowledge next to your side
- a couple of hand to help out with the swap
- 6 pack of corona beer
that pretty much it if your just doing the engine swap only. Good Luck.
snotsmear
May 16, 2017 01:25 PM
Nic Graham
Aug 11, 2014 02:40 AM
dlb958
Apr 17, 2011 12:02 PM
turbohonda
Jul 24, 2010 10:56 PM
Drissle
Oct 29, 2008 09:18 AM
