Weird Starting issue civic 1990
Old Aug 11, 2023 | 02:34 PM
Garcia29's Avatar
Default Weird Starting issue civic 1990
I owned a 1990 civic ef. When ever I try to start my car there is no crank for about 3-5 times but then the car turns on. This is my daily car and this issue has happened for about a month. Although it this occurs for most of the time, it has always turned on. Any ideas of what it could be causing this?
Old Aug 11, 2023 | 03:00 PM
Ignition switch, relay?
Old Aug 11, 2023 | 10:18 PM
First thing to do is to clean the battery posts and cable terminals
Inspect the terminal crimps. Sometimes corrosion get under the insulation
Follow negative cable to chassis ground. Clean contact points.
Then check the engine ground strap clean as necessary.
This will eliminate corrosion and make testing easier.
Old Aug 12, 2023 | 07:27 PM
nvto's Avatar
i was gonna say the same thing avi said about the posts and terminals, check out for those
Anthony William Garcia-Wolff
Jan 22, 2013 09:23 AM
tdow3
Oct 10, 2012 04:46 AM
built zc
Jan 10, 2009 04:19 AM
SoCalDude
Nov 29, 2006 07:17 PM
cosmo
Jul 25, 2006 12:25 AM
