what can i do? i got a stripped bolt.
Old Feb 5, 2009 | 08:22 AM
da1ed7's Avatar
Default what can i do? i got a stripped bolt.
i have a stripped bolt on my tension pully. what can i do to get it out?
Old Feb 5, 2009 | 11:51 AM
civicivic90's Avatar
you could take a grinder, grind a little slot in it and turn it into a flat head screw...
Old Feb 5, 2009 | 04:07 PM
da1ed7's Avatar
but there is no space. i got about 5 inches. i was thinking of grinding the head of the bolt take off the pully and take the rest of the screw out with a pressure plier.
Old Feb 5, 2009 | 10:02 PM
josh2113's Avatar
Member
Cool
Which tension pulley is it? Is it for the A/C or is the timing belt? Is it just the head of the Bolt or is cross threaded and won't come out? If the head of the bolt is stripped I would get a GOOD pair of vice grips or I would use a turbo socket. If possible I would also try to move the engine up or down to increase clearance for tools. Disconnect motor mounts and try either jacking up the motor (make sure you have a block of wood between the jack and the oil pan) or lowering it down it may make the difference of getting it out. Hope that helps
usahoe18
Dec 19, 2014 03:28 PM
PartsManTypeR
Oct 6, 2013 08:44 AM
Hondagal1
Sep 20, 2013 11:50 AM
civicparts4you
Mar 10, 2008 11:05 AM
redintex
Nov 27, 2006 08:21 AM
