2000 Civic SI cutting out when i try to accelerate and v-tec problem?
Old Feb 25, 2010 | 06:22 PM
chunk0806's Avatar
Default 2000 Civic SI cutting out when i try to accelerate and v-tec problem?
2000 honda Civic SI, with a B16-A2.
ok, i'll start off with the v-tec problem. for the past 2 weeks my v-tec has randomly decided to stop working. It sometimes feels like working randomly with no sign when or why.
I have tried just about everything, im throwing code 22 which is a v-tech malfunction code. here's a list of things i have done to fix with no luck.
-replaced v-tec solinoid
-replaced oil pressure sensor for v-tec
-change oil and filter (full synthetic)
-replaced the Idle Air Control Valve (IACV)
-cleaned all screens and replace the entire
-replaced the Map Sensor
-Cleaned all points in distributor
-replaced Plugs
-checked and changed all coolant
-Had codes swiped off of ecu many times
-Removed ECU overnight to swipe codes many time
-Unhooked Battery many times to swipe codes
-wiggled and moved around all wires and checked all connections that I could see or touch.
-tried to clean out the intake with intake and carb cleaner...
-tried a fuel additive
-check to make sure fuel pump is putting out the correct steady PSI
-Changed fuel filter
(I'm going very broke very fast)
Secondly- recently i developed a problem that it flashed code 6 (temperature sensor) for a while and now I cant get it to come back, but it was there for a while. I start the car up in the morning or anytime the engine is cold, and drive the car, (other than the v-tec issue) It runs great (and usualy the v-tec works when it's cold). but later when the car reaches it's normal running temp it starts to cut out everytime I try to accelerate. It idles great and drives great as long as im not on the gas.
I'm overly confused and dont know what the F is going on. please help, because I dont have the slightest clue as to what to do next. thanks for your time and help.
t-roy
Dec 9, 2013 03:33 PM
awesomehog
Jun 9, 2010 11:33 PM
jaejae25
Jan 25, 2009 08:25 PM
crazy900rr
Aug 9, 2007 01:41 PM
bblair
Aug 18, 2006 12:43 PM
