91 Honda ex please help me
Old May 12, 2015 | 01:55 AM
Denzelstroman's Avatar
Default 91 Honda ex please help me
I have a 91 Honda I bought about three months ago once I fixed it up a little and was about to drive it the car kept deceleration and the speedometer didn't work but shifted just fine. Then a few weeks later the tranny stopped shifting automatic so now Manuelly shift it. I thought the tranny was gone but I'm trying to at least try everything before I buy a new one. I replaced the vss and that fixed the speedometer and decelerating I also changed the solenoid yet when I put the car in drive it takes in like second or third gear. My s light on the dash hasn't stop blinking since I got the car please help me!!! Do I need to replace the TCU or is it anything else I need to change before I buy another tranny?
Old May 13, 2015 | 02:34 AM
welcome to the forum. Did you change the trans fluid by any chance while fixing up a little.
Old May 14, 2015 | 12:17 PM
Yes, but when I was changing out the solenoid last week the fluid did look black. Any suggestions?
Old May 15, 2015 | 02:21 AM
what type of transmission fluid did you use.. If you used anything else other than the honda transmission fluid only, ( From Honda Dealer) the problem may have started from there. If this is the case, please change the fluid again back to honda only fluid, this may help the trans problem (hope)..
Old May 16, 2015 | 12:00 AM
Okay thanks I'll try it. I'm also changing the TCU hopefully that works too
okhozi
Jan 6, 2010 09:10 AM
nathancrowder
Oct 23, 2008 12:28 AM
91hondaaccord
Jul 21, 2008 05:15 PM
hondatuner14
May 7, 2007 09:07 AM
gkinsha
Feb 3, 2007 05:29 PM
