98 civic code engine light emissions
So my check engine light came on. I checked it and two codes read: P1457(emissions) ; P0303(cylinder 3 misfire). What do these mean and how can I fix them? I also might have an exhaust leak which may be the cause of something wrong with my fuel injector. Please help!? Thanks
welcome to the forum. if you have high milage on your engine and have not done a tune up, check/change or replace the spark plugs, plug wires, and (clean ) injectors. then have the codes removed and see if they return.
Mike Heenan
Nov 18, 2013 06:54 PM
hoss8383
Sep 13, 2013 02:55 PM
