Aside from a Check Engine Light....
Old 10-30-2015, 01:56 PM
PCollen's Avatar
Default Aside from a Check Engine Light....
...what would be the problem with my driving without the gas cap tightened sufficiently ? Low fuel pressure ? Poor mileage ?
Old 11-04-2015, 08:04 AM
just the gas cap light stays on, and you're allowing gas fumes into the air. fuel pressure will be good, milage will be good, engine runs good.
Old 11-05-2015, 06:12 PM
lowlife9's Avatar
gasoline evaporates very quickly so yes you would get less MPG.
Old 11-08-2015, 08:46 AM
And very annoying
Old 11-08-2015, 08:40 PM
commonname's Avatar
Member
Plus the awful smell of gasoline that could trigger a fire if someone is smoking near your vehicle.
Old 11-10-2015, 06:54 PM
PCollen's Avatar
OK...thanks for these responses to all.
Now if I were thinking that I may have issues with my EVAP canister or solenoid (I'm sure you're familiar with THAT topic) , could simply not tightening the gas cap and allowing any fuel vapors to vent out the tank filler tube vs. needing the "services" of the EVAP system, be an effective way of perhaps ruling out that the EVAP system was in fact malfunctioning ?
fyah17
12-22-2012 03:03 PM
samuel_gatech
11-04-2009 04:46 AM
silverbullet
02-19-2007 08:26 PM
cpatd
11-13-2006 02:03 PM
whermanov
09-23-2006 04:16 PM
Quick Reply: Aside from a Check Engine Light....
