civic window
Old Mar 17, 2010 | 09:50 PM
socal07's Avatar
Default civic window
I have a 1997 civicEX. I had the passenger window motor replaced and the window doesn't go down, it only works going up. I switched out the master switch and pass switch, but with no luck. All the fuses are good. Any suggestions.
Old Mar 18, 2010 | 05:52 AM
welcome the forum. I got this off yahoo answers. 1. verify the power window lock switch is off 2. Hold the front passenger window switch in the down position and ground the Blue/Yellow wire at the front passenger window switch andsee if the window goes down. 3. If so, ground the Blue /Yellow wire at the power window master switch and see if the window goes down. 4. If not, check the Blue/yellow for an open between the front passenger window switch and the power window master switch - check the door jambs in the right and left doors for the broken Blue/Yellow wire.
Old Mar 31, 2010 | 09:11 AM
Laurence's Avatar
Thanks mate..!! Its all good to notice the posts and the replies too..!!
rthawley2
Feb 11, 2011 02:47 PM
jmurphnd
Aug 29, 2008 11:47 AM
slilley92
Jun 28, 2008 11:27 PM
han_doi
Nov 18, 2006 02:52 AM
