Fail Inspection because of Struts
Old Sep 6, 2015 | 07:02 AM
caldwellrv's Avatar
Default Fail Inspection because of Struts
Purchase a 2007 Honda coupe and had to get a MD state inspection. It fail because of the vehicle was to low because of struts, not because they were bad, because they where the wrong struts. My question is, is there anything can be done with the struts on the vehicle?
Old Sep 8, 2015 | 09:47 PM
lowlife9's Avatar
by wrong strut im assuming you mean there after market performance ???. are they adjustable at all do they have threading if not then your only option it to buy stock suspension or an adjustable after market suspension. how low is the car to warrant a failure post pics of ride height and suspension. also it could be that you have lowering springs on the stock suspension in that case you would just need stock springs but unless you post pics we can't tell you.
Old Sep 22, 2015 | 08:16 PM
caldwellrv's Avatar
You are correct, I believe someone lower the coil spring assembly because I am told I need to fix with repairing the "Strut Assembly/suspension Strut and Coil Spring Assembly for Left, Right and Rear".
Old Sep 24, 2015 | 05:21 PM
lowlife9's Avatar
well if there stock shocks and struts then you just need stock springs to raise it up. after market springs usually only lower the car less then 2 inches and are DOT compliant so im not sure why that would warrant a failed inspection unless you live in some kind of **** state or australia.
Bill_S
May 9, 2015 06:52 AM
tmonahan_1
Nov 2, 2011 07:11 AM
civic_dude
Jan 28, 2010 11:37 AM
joef
Jan 14, 2010 11:10 AM
Philsy
Jul 2, 2007 06:22 PM
