Help/insight much appreciated. (acceleration issues)
I have a 1998 Honda Civic EX and have been experiencing some acceleration issues. When I first drive my car everything runs fine, but when it's been going for a while (say 20 minutes on the freeway) it has issues with acceleration. When I come to a stop then come to push the gas the car takes a lot longer to move/accelerate. It picks up speed for about half a blockthen it shifts and continues into normal acceleration. But when I come to a stop sign or a stop light the process starts all over again with a crawl at first and then it picks up speed then it shifts to normal acceleration. This only happens AFTER the car has been run a while. I took it to a mechanic on Monday and had the exhaust manifold replaced (as it was broken) and it ran fine for 2 days, then the issues started again.
Any thoughts or suggestions would be greatly appreciated.
RE: Help/insight much appreciated. (acceleration issues)
Thanks ac. I took the car into the mechanic this morning and will hopefully hear something good about it today. I mentioned the 0-2 sensor to them as well as the V-Tech solenoid. I was also told it could potentially be the fuel pressure/fuel pump/ fuel filter, or something with the exhaust system.
something you can do to help the dealer or anyone to troubleshoot your car, write the time of day and when you start your car, run, how long and what it does.This helps a dealer and gets them away from saying, can't find anything wrong, its not doing it now.
Was just told by the mechanic that the timing was off, which they offered to adjust that for free since they were the ones who changed the timing belts less than a year ago. They said the o-2 sensor checked out fine as well. I was also told by a friend that it could be the throttle body or fuel filter? is this possible even though it only occurs after the car has been run a while?
nwolfson
06-03-2009 03:54 PM
