Need Help!!
Old Sep 23, 2009 | 10:45 PM
Kremser25's Avatar
Default Need Help!!
Ok so i just bought a 1989 civic hatch..I cant figure out why it wont turn over..There was oil in the coolant over flow along with in with the spark plugs..also its a stock D15b2 and has an SI computer i cant figure out why it wont run?
Old Sep 24, 2009 | 06:58 AM
Welcome to the forum. You say no turn over, check the battery for voltage and clean terminals, check the starter to see if it works at all and has good 12 volts, do you have good clean gas and carb or injecter system clean, and fuel pressure. fuel filter good, air filter clean. This is a start.
Old Sep 24, 2009 | 09:32 PM
Kremser25's Avatar
yeah i checked all that it wants to turn over but wont start..but i looked at the timing belt today and it looks to be 180 degrees off...and i could pulll it off by hand...would that prevent it from starting????...im new to hondas i use to build mini trucks so im kinda lost...
Old Sep 24, 2009 | 09:33 PM
Kremser25's Avatar
thank u by the way....
Old Sep 25, 2009 | 07:00 AM
yes it can
Old Sep 26, 2009 | 08:51 PM
Kremser25's Avatar
thanks u im going to try that tomorrow and ill let you know if it worked
Old Sep 27, 2009 | 11:08 PM
Terry's Avatar
yes, check that the timing belt has not got any broken off or worn teeth. sounds like u need a new timing belt change? What's the kms on yr dash? it must be over 200 000 kms?
okhozi
Jan 6, 2010 09:10 AM
90civicDX
Apr 1, 2009 09:32 AM
91hondaaccord
Jul 21, 2008 05:15 PM
