P0780 and p1731 2005 Crv
Old Jan 16, 2022 | 06:48 PM
Rick G's Avatar
Default P0780 and p1731 2005 Crv
Trans slipping in drive. I put it in 2nd gear on shifter and drove home with no slipping. Bad solenoid? Or trans fried?
Old Jan 16, 2022 | 11:11 PM
welcome to the forum hope you are using Honda ATF only. no aftermarket fluid. easiest to do is a trans fluid change if you have not done one in the year. if its the first time, change fluid and run for a few days, change the fluid again, run for a few days then change for the 3ed time. or take to a shop that uses honda only atf and have them change the fluid.
Old Jan 18, 2022 | 01:44 PM
I know that sometimes the "D" in the PRND21 will flash if the solenoid becomes an issue. Changing or doing a drain and fill sometimes helps??
Not a tranny specialist and unfamiliar with this issue.
jsmith0381
Feb 4, 2021 09:00 PM
Bigfoot1957
Oct 19, 2017 05:20 AM
transguy37
Jan 28, 2009 10:58 PM
meamanca
Jul 27, 2007 07:14 AM
