VERY dim low beams, can’t find fix
Old Jul 10, 2022 | 01:46 PM
chromebans's Avatar
Default VERY dim low beams, can’t find fix
2012 civic LX. Low beams are so damn dim I can’t see jack. First buffed and polished lights, then changed fuses, adjusted up/down position, changed bulbs twice. Took to 2 local mechanics, both ran elec dianostics on alternator, battery, grounds, said they found absolutely nothing wrong and that the lights seemed fine to them. They suggested maybe the headlights themselves were corroded on the inside so I bought new ones. Still the same brightness. Any ideas?
Old Jul 10, 2022 | 03:34 PM
My thoughts are that's the way they are.
Old Jul 11, 2022 | 01:04 AM
It is difficult to judge without actually seeing the headlight assembly
Can not tell if the lens is cloudy
Can not tell if the bulb needs changing
Can not tell if the ground or wiring is the issue with out testing
Did you try the brighter bulbs??
Auto parts stores have 30%, 50%, and 100% brighter than standard bulb brightness.
Old Jul 13, 2022 | 03:09 PM
welcome to the forum: check and clean the ground wires attach points.
Old Oct 6, 2022 | 04:10 AM
JohnAndy's Avatar
If you care about brightness, I would recommend you replace your low beams with LEDs.
Old Oct 15, 2022 | 08:18 PM
rrkeroack's Avatar
I feel the same. I have a 2022 models so cloudy/ dirty lenses are not the issue. My local dealer tells me there is no fix and if I go to an aftermarket’s replacement it may void my warrantee. Any thoughts?
longtbjo
Jan 5, 2022 11:05 AM
JennyBoo311
Mar 4, 2021 07:06 PM
sh3d3vilinme
Feb 10, 2009 10:18 PM
jaggermiester
Jan 1, 2009 09:58 PM
