250 W/Constant Beep
Old Mar 3, 2023 | 11:26 AM
vollender's Avatar
Default 250 W/Constant Beep
I have a 250 Honda on a government boat. It is a constant beep beep beep. I have it hooked to diag on computer, there is no codes. I tried the jump wire way to and no light will flash.
I service the engine last year. It ran great, they picked it up and put new batteries in. Well the hooked them up wrong and it blew the 150 amp bar fuse in box. I replaced it and now it is charging properly. I tried another horn and same thing constant beep. On gauge it has a wrench that flashes with every beep.
What should I look for
Old Mar 3, 2023 | 12:49 PM
Get the codes. If it's flashing you have a code. Need better tool.
Old Mar 3, 2023 | 02:37 PM
vollender's Avatar
The red code light does not flash, only gauge with wrench on it. I also tried jump wire on diag plug and no flashes for code.
Old Mar 3, 2023 | 05:28 PM
Sounds like the module has failed.
Old Jun 11, 2023 | 09:55 PM
SilverC's Avatar
reset oil change due alarm?
Ernest
Jun 12, 2021 08:39 AM
DitchWater
May 3, 2021 05:44 PM
jboxford
Jun 29, 2017 02:45 AM
3034mango
Nov 25, 2011 06:44 PM
lashalee
Apr 11, 2008 03:09 AM
