BF40 Runs shaky and rough when first engaged into hear
Old Jul 13, 2018 | 06:36 AM
Ben Richardson's Avatar
Default BF40 Runs shaky and rough when first engaged into hear
So I have a 99-2000 Honda Bf40 (I think that's the year) and since I've bought it I can't really seem to get it to slow idle smoothly in gear. It idles fine when it's in neutral but once I out it into gear it starts to shake and run rough almost like a misfire or fouled plug. The plugs are brand new, carburetors are newly cleaned, and I have brand new non-ethanol fuel. I was just wondering what plan of action I should take to adjust this. Maybe if I should put the boat into gear and adjust the idle while it's moving/under load or maybe there's other suggestions? Any help or ideas would be greatly appreciated!
Old Jul 20, 2018 | 03:17 AM
welcome to the forum is the idle 950 + /- 50, and are the carbs syn proper ( mixture screw)
Old Jul 20, 2018 | 12:49 PM
To be honest I have no idea. I don't know how to gauge the idle to those RPMs since I don't have the tool, and I'm not sure where to go to get one either. I'm not sure if the carbs are synced either, I believe so but I'm not positive
Old Jul 20, 2018 | 08:10 PM
if you can locate on line or at a library a service and owners manual for your engine, it would be a lot easier to see how to get your engine in tune. also the tools needed to fix what is needed to keep it up to running well.
tommyvegas76
Oct 22, 2015 02:08 PM
Carmen
Oct 31, 2012 11:18 PM
james9120
Aug 30, 2010 01:51 PM
benjammin
Sep 1, 2009 07:09 AM
hondafied
Mar 17, 2007 01:49 PM
