BF50 Outboard bad machining in oil passage
Old 08-13-2016, 09:19 PM
spindr's Avatar
Default BF50 Outboard bad machining in oil passage
Hi All,
New to this site and looking for some advice.
Purchased a used 2009 150hp outboard, compression check < top cylinder down : 200, 150, 180, 205. I checked the valve clearances all the intake where good but the exhausts were tight, # 2 had less than .002" clearance. I took the head off and found the # 2 cylinder exhaust valves badly burnt. I order new stuff and cleaned the cams and head.
During reassembly i found an oil passage in the cylinder block (see pictures) with i very large piece of aluminum sticking straight out of the drilled hole. it needs to be removed, but Im not sure how? and Do you think i should contact Honda?
Thanks for your help!
Attached Thumbnails BF50 Outboard bad machining in oil passage-img_1245.jpg   BF50 Outboard bad machining in oil passage-img_1247.jpg   BF50 Outboard bad machining in oil passage-img_1248.jpg
stevepic
12-12-2015 10:10 AM
seabird
03-24-2014 08:36 PM
kentuckyfisherman
01-05-2014 01:15 PM
lmontalto
02-17-2010 04:11 AM
mjh
05-03-2008 11:03 AM
Quick Reply: BF50 Outboard bad machining in oil passage
