Oil overfill question
Hi. Newish to boating and I made a blunder. While trying to change the oil in our Honda 20hp outboard I inadvertently drained the gearbox oil, then added a quart of oil to the engine oil. Now the engine oil is probably double what it should be. To complicate things I can’t unscrew the engine oil drain plug! I’ve not run the engine and I’m wondering if that much oil sitting in the engine, until I can drain it, will cause problems. Plus I have to now go get gearbox oil. The boat isn’t in the water yet for the season. Any help would be much appreciated.
thanks.
thanks.
