Honda Scooters Information on Honda's economical scooters.
'02 Metropolitan questions: fuel lines and air box
Old Nov 4, 2020 | 08:21 AM
DeeJais's Avatar
Default '02 Metropolitan questions: fuel lines and air box
I'm working on an '02 CHF50 that sat for years with gas in the tank/lines. I bought 3/16 automotive fuel hose from an auto parts to replace the lines. I found the hose goes onto the carb fittings easily enough, but I struggle very much getting the plastic fuel filters into the hose, so much that I fear breaking them. Is it overkill to use automotive lines, or can I use a softer hose that will accept the fuel filter fittings better?
Also: I'm getting rid of the air box. The housing is broken and I think perfomance will be generally better with a cone air filter. I've read about changing the carb jets after deleting the air box, but is that 100% necessary, or just a performance suggestion?
Apologies if these are dopey questions: This is my first Honda, I've only worked on Chinese scooters until now. Thanks.
Kevin M McGrath Sr.
Nov 3, 2020 08:04 AM
muncie
Jan 5, 2015 10:53 AM
rayh2
Aug 12, 2009 12:38 PM
Wai
Jul 1, 2009 03:16 AM
uanrap
Jan 2, 2009 07:03 PM
