Honda Scooters Information on Honda's economical scooters.
2016 ncw50 has a ticking noise and won’t idle
Old Jan 17, 2020 | 04:45 PM
Flippingscoots's Avatar
Default 2016 ncw50 has a ticking noise and won’t idle
I just bought a 2016 Honda metro (not running) for a couple hundred bucks and figured it would be an easy fix. Turns out it was easy to get it started. (Jumped it with a 12v battery) took a while of cranking to get it to finally run. All fuses were in good shape (checked with a multimeter) and the bike seemed to be in good over all physical condition but I did spot that is has 11k miles. So once I got it to turn over I was able to ride up and down my street but it has a tapping sound that gets louder the higher the rpms go. Also I can’t get this thing to stay running at idle no matter how I adjust what I’m guessing is the the idle adjustment screw (under the seat in the small access hole). I’m thinking of taking it in to a local Honda powersports mechanic but figured I’d ask the Honda forum if anyone has any suggestions before I do. If it needs a valve adjustment or anything like that I probably won’t be able to do that without some sort of walkthrough/video guidance as I’ve only ever rebuilt carbs on the older 2 stroke style scoots. Thanks in advance for any info!
Old Jan 18, 2020 | 02:38 AM
welcome to the forum. you guessed what i was going to suggest, adjust the valves. might be just easier to have the mech do the adjust, you can ask to watch to learn how to do it,.
Ben Richardson
Jul 20, 2018 08:10 PM
cadillac curry
Jun 19, 2010 12:01 AM
hroc2
Aug 7, 2009 02:51 AM
Jessie
Sep 1, 2008 12:10 PM
franwagner
Jul 9, 2008 04:31 PM
