Honda Scooters Information on Honda's economical scooters.
2020 Metro - can't find coolant gauge
Old Jun 8, 2020 | 07:37 AM
CenTenn's Avatar
Default 2020 Metro - can't find coolant gauge
Just bought a 2020 Metropolitan (built in Dec 2019) and read manual about how/where to check fluids. The manual (says "2020" on cover) says to open seat and look through the clear plastic window to see the coolant gauge. I can't see anything there but a red tab with a "+" on it, which I guess is attached to the battery. Anybody know what I'm doing wrong? Is the manual wrong? Thanks!
Old Jul 10, 2020 | 08:55 AM
chicagobob's Avatar
It means look at the coolant tank to see the fluid level. There's no gauge. Just the bottle itself. Same thing as in a car.
Old Jul 10, 2020 | 11:02 AM
CenTenn's Avatar
Guess I wasnt' clear. The manual indicates you can see the coolant tank level (I said "gauge" which was wrong) through a plastic window in the seat storage compartment. It appears I have to remove the seat storage bin (4 screws?) to see the tank?
Old Jul 11, 2020 | 04:15 PM
chicagobob's Avatar
Easier to just remove the maintenance cover (p.69 in the manual), open the reservoir cap and look inside.
Old Jul 14, 2020 | 10:19 AM
CenTenn's Avatar
Got it! Thanks. After opening it and looking at the reserve tank, I see that I was not looking low enough (and to the left) to see the reserve tank markings through the (semi-) clear window in the seat storage compartment.
Old Jun 8, 2022 | 03:57 PM
rcspencer1's Avatar
I have a 2019 metro that I can find the reserve tank but no cap to take off to add coolant. The users manual (see pic) shows it in the seat and simply says to add coolant if it's low (see pic below), but I cannot find the cap for the life of me. Thanks for any thoughts/recommendations you might have.
Old Jan 8, 2025 | 11:58 AM
LBMETRO's Avatar
I am having the same issue as I also have a 2019 Honda metropolitan I have no coolant in the reservoir and I am trying to fill the reservoir up cannot find out where I am supposed to fill that up at. I'm guessing I have to probably take some screws out of the seat or something and take that off somehow or something but the manual does not explain this problem you are correct and I don't see anybody that has answered your question so I am stuck as well
loganschambers12@
Apr 5, 2020 06:52 PM
Earthcritter71
May 22, 2011 07:55 PM
Earthcritter71
Apr 27, 2011 12:35 AM
scott1ct
May 21, 2007 11:22 AM
