Honda Scooters Information on Honda's economical scooters.
Headlight just went off and won't come back on
Old Aug 24, 2023 | 02:16 PM
Lriggs78's Avatar
Default Headlight just went off and won't come back on
I have a 2002 honda metropolitan scooter.. i was driving down the road and went to switch my bright lights on and when I did it appeared dim. So I switched it off brights back to low beam and it came back on for about 2 seconds then light went out completely and had never came back on since. Changed the bulb , wasn't that checked fuses and they are ok. What else can I check??. Also all my brake lights, turn signals all work fine and the speedometer light works to
Old Aug 25, 2023 | 01:25 PM
dbuzz's Avatar
Member
without looking at the shop manual i would cycle the low/high beam switch many times even pushing don on the switch s you do it. other than that you would have to obtain a shop manual and see what other parts are involved
Old Aug 26, 2023 | 11:55 AM
Wiring and switch are to be examined.
Old Aug 26, 2023 | 06:06 PM
Lriggs78's Avatar
Yea gonna check that tomorrow
Old Sep 2, 2023 | 03:34 PM
Lriggs78's Avatar
So checked the switch and wiring all seems to be good. Everything else works except the headlight I don't know what to even think it could b now. New bulb new fuses.. help
Old Sep 2, 2023 | 03:58 PM
dbuzz's Avatar
Member
I would check the connection at the bulb for corrosion and look around for a service manual that would have a wiring diagram. manualslib.com has some, you may have to cruise around through a few manuals to see if anything else is in the circuit like a headlight relay and where it is.
Old Sep 2, 2023 | 09:40 PM
Also look at the siring to the socket for any bulges. You may need to open up the harness.
Old Sep 3, 2023 | 04:58 PM
Lriggs78's Avatar
Ok will do. Thank you
Old Sep 5, 2023 | 07:28 PM
Lriggs78's Avatar
I've literally checked everything and still no headlight. Just doesn't make sense that all my other lights work scooter runs fine battery's fine ughh
Old Sep 5, 2023 | 09:12 PM
  #10
If that were true you would have found it. Do you know hos to trace wiring?
