Honda Scooters Information on Honda's economical scooters.
Honda Metropolitan II Starting Issue
Old Jun 28, 2021 | 09:29 AM
KowPie's Avatar
Default Honda Metropolitan II Starting Issue
Greetings From The Land of The Alamo!
I have a perplexing problem with my Honda Metro.
It will not startup initially unless I take the top & vacuum piston off the carb and pour in a small amount of raw fuel. After that it starts up and runs fine.
I have cleaned the carb, replaced jets & replaced bystarter. What else should I be looking at?
Paul Farrell, San Antoine
Old Jun 28, 2021 | 05:24 PM
welcome to the forum. remove the drain screw out of the carb w/switch on the fuel pump should pump gas and drain out of the drain screw area.
Old Jun 28, 2021 | 07:07 PM
KowPie's Avatar
Hello There & Thanks for The Speedy Response. Please tell what is the problem I will be addressing with this procedure? I can hear the fuel pump clicking and once started the engine runs good.
I appreciate your insights.
Old Jun 28, 2021 | 08:25 PM
Check for weak spark
You might have spark but a weak spark will not ignite the fuel
Dumping raw fuel in to get the engine to crank fast enough, might help the spark
Next check to see if fuel pump is running while crank engine.
Desire6162
Aug 27, 2017 07:28 PM
ForrestForce
Feb 17, 2017 10:56 AM
wolfbone
Mar 12, 2011 07:47 PM
splat41
Aug 27, 2008 09:21 PM
weissmj
Dec 9, 2007 05:52 PM
