2023 Honda HRV Rear differential pump (current Amp)
Old Feb 8, 2025 | 06:57 PM
Paul.Wright's Avatar
Default 2023 Honda HRV Rear differential pump (current Amp)
Hello, trying to diagnose the All wheel drive issue on my 2023 Honda HRV, rear diff pump is replaced, awd module replaced but still getting the error for rear diff pump motor current is low,C1851-18 1) Confirmed
Motor Circuit Low Current
after replacing the pump the issue didn’t resolved so i took it to honda and they diagnosed and suggested to replace the AWD module which i did and still have the same issue,
i want to find out How much the current amp should be in the rear diff pump motor.
The DTC code for honda hrv 2023
Old Feb 9, 2025 | 04:46 PM
You need to test the circuits instead of throwing parts at it. Take it to a shop that does electrical.
Old Feb 9, 2025 | 09:27 PM
Default Read the my post and then answer
Read the post and then answer: i mentioned that i took it to Honda dealer and they tested everything that needs to be tested and suggested to replace the module, which i did, in here i am looking to find out the standard amp in the diff pump
Old Feb 10, 2025 | 08:05 AM
Most dealers throw parts at cars. Do what you want.
Old Feb 16, 2026 | 08:49 PM
cj banda's Avatar
Default 2024 honda crv rear differential
  • Hi friend, I have the same problem and I've already done everything you did: I changed the oil, the pump motor, and also the AWD module. I'd like to know if you were able to solve this problem.
Old Feb 17, 2026 | 12:22 PM
Just Ducky's Avatar
IIRC there is a TSB 23-031on the subject however if the motor was replaced it is likely not the issue.
The DTC also indicates that there may be a communications loss. So I’m with @grcauto on this. You need to check connections end to end.
ThomasX
Sep 22, 2023 05:35 AM
Kateb
Dec 27, 2017 12:10 AM
islander73
Feb 14, 2013 11:09 PM
nicosuave23
Sep 22, 2011 07:33 AM
