Help please
Old Mar 12, 2022 | 09:13 AM
Jamiecrv84's Avatar
Default Help please
Hi everyone i have a 1999 honda CR-V an im trying to figure out what is going on with it. Ok so from a cold start it will start just fine an run normal but if i drive it for a bit then turn it off an try to restart it sometimes it wont start unless i let it sit for about 20mins or so but sometimes it will start but the my rpms are running high an it will not go down when this happens the rpms sit at about 2000rpms.. iv replaced the distributor,plugs, wires, idle control valve, throttle plat an nothing seemed to help it im about to put in a timing belt does anyone know if this will fix the problem im having? Please lmk i love my car and want her back to normal. Thanks
Also i have no check engine light on.
Old Mar 12, 2022 | 03:47 PM
Purge valve maybe.
Old Mar 12, 2022 | 06:09 PM
Jamiecrv84's Avatar
Purge valve maybe.
Ill try that if the timing belt doesn't fix it.. but i also have no check engine light on 🤷
Old Mar 12, 2022 | 07:46 PM
Clamp off the hose and see if it cures it.
Old Mar 12, 2022 | 11:27 PM
Jamiecrv84's Avatar
The hose to what?
Old Mar 13, 2022 | 02:23 PM
Between the purge valve and the intake.
Old Mar 18, 2022 | 07:47 AM
Jamiecrv84's Avatar
Replaced the purge valve didnt help the only other thing i can think of it being is the crankshaft position sensor everything else that involves this issue that i can think of iv replace so the crankshaft position sensor is the only other thing. If this doesnt fix it i give up...
Old Mar 18, 2022 | 07:44 PM
The crank sensor is the first thing you should have done. I thought it was new.
Old Mar 20, 2022 | 12:50 AM
Just wondering, ... Why would the crank shaft sensor cause a fast idle? No start, yes??
Old Mar 22, 2022 | 05:31 PM
  #10
Jamiecrv84's Avatar
Well replaced the crankshaft position sensor an its still doin the dont want to start after iv been driving it.. so idk what else it can b...
