Honda brake fluid?
Old Oct 6, 2014 | 07:31 PM
c east's Avatar
Default Honda brake fluid?
My mechanic refuses to put anything but Honda HD dot3 Fluid in my CRV...It is all dot 3 What gives?...Charlie
Old Oct 6, 2014 | 08:31 PM
lowlife9's Avatar
Genuine Honda DOT 3 brake fluid is formulated to minimize water absorption under all conditions. It has one of the highest boiling points in the industry. That's important in sustained use such as driving on hilly terrain that can heat up brake rotors and calipers. When tested in a mass spectrometer, Honda Brake Fluid had dramatically less dissolved copper material than the leading competitors, clear proof of superior corrosion protection. Always use Genuine Honda DOT 3 brake fluid. If it is not available, you should use only DOT 3 fluid from a sealed container as a temporary replacement. However, the use of any non-Honda brake fluid can cause corrosion and decrease the life of the system. Have the brake system flushed and refilled with Honda DOT 3 brake fluid as soon as possible. Brake fluid marked DOT 5 is not compatible with your car's braking system and can cause extensive damage.
Old Oct 11, 2014 | 07:56 PM
And be careful when using these quick lube places,when they top off fluids they seldom use the right brake fluid.
Old Oct 20, 2014 | 05:57 AM
car1o's Avatar
You can use other brands as long as it is dot3. Dot4 can be used also. Just don't get the dot5 because it is silicone base.
Old Oct 7, 2018 | 12:05 PM
cookieman's Avatar
Default Brake fluid
I have Pro Honda brake fluid # 08203-0004 is this fluid on for motorcycles can I use for my 2009 Honda CRV brake system
Old Oct 8, 2018 | 01:09 AM
brake fluid made by honda can be used on a honda motorcycle or car, as long as it is dot 3 or dot 4.
Old Oct 8, 2018 | 11:13 AM
cookieman's Avatar
Thanks, Just wanting make sure.
harvill
Oct 26, 2019 09:21 PM
ivory88
Oct 7, 2016 08:40 PM
89crxhf/nasty\
May 18, 2011 09:51 AM
CCCtheking
Sep 1, 2009 12:22 PM
CCCtheking
Aug 1, 2009 03:14 AM
