PLEASE HELP 2014 CIVIC DC-DC Converter?
PLEASE HELP: Went to get a bad axel replaced on passenger side of 2014 hybrid civic, and 4 days later was driving in the rain and was braking to make a turn and the car immediately had brake system, charging system and IMA all pop on at once. I took the car back to where the axel repair was done and they said they didn't know what was wrong and to take it to honda dealer. I did and they said it's the DC-DC converter, but I just find it hard to believe it failed right after having axel replaced and suddenly. I haven't picked up car from dealer yet to see the code read out and ask if they checked fuses or grounding/wiring but I doubt they would check so they could just try to bill me 3k to replace DC-DC. Am I over thinking this and this is a normal thing that happens or should I investigate further?
I hear what you're saying, but I was under the impression that the grounding straps and connecting wires were on the side of the axel that was replaced and something might have been loose or exposed, and the water from the rain may have caused the issue since no other signs of dimming lights or losing power ever showed up prior which it seems from what I could gather that usually there are signs prior to going bad.
ABS light is on if I remember correctly.
Just got back from Honda, and they said it's a faulty power inverter unit, codes: p0a78 & p1440.
I have been looking up used or lower costing parts for this because Honda quoted 2400 on the part, and 750 labor @ 4.5 hrs.
I have been slightly confused on the replacement part I need:
https://www.walmart.com/ip/12-13-14-...31/14546571394
https://www.ebay.com/itm/156812826342
or
https://honda.oempartsonline.com/oem...er-1c800rw0003
or
https://www.ebay.com/itm/146616165235
If you could help point me in the right direction that would be great for the part, looks like I can do the labor myself, and get them to reprogram the computer after if that's needed.
Thanks for the help.
or
or
Thanks, I'll double check but I think I won't qualify when I briefly looked on chatgpt, it said 150k miles and I just hit 200k.
JFS3
Oct 20, 2023 08:55 PM
SonLPham
Jul 13, 2023 04:02 PM
