Remove front wheel hub
Old May 18, 2026 | 11:15 AM
tomcod222's Avatar
Default Remove front wheel hub
I have a 2025 Honda CR-V with a damaged front wheel stud. My question:: Can I pull the outer wheel hub containing the damaged stud out of the inner race of wheel bearing with a sliding sledge hammer tool without removing the knuckle from the vehicle?
Thanks for any info on this.
Old May 18, 2026 | 02:43 PM
Just Ducky's Avatar
Default Not Hammer Time
If you remove the circlip on the back side of the hub you should be able to pull it out. I would use a hub puller and not a hammer.
That said, an entire new hub assembly is under $75.00. Just be careful with your ABS wheel sensor.
atomic67
Dec 5, 2022 03:33 PM
Nkoby97
Jul 5, 2021 10:02 PM
Redbeardpilot03
Dec 30, 2020 07:22 PM
yrk
Oct 15, 2009 11:59 PM
