04 odyssey no start sometimes
Old Jul 16, 2023 | 05:45 PM
NotYourAverageShadeTreeMechanic's Avatar
Default 04 odyssey no start sometimes
Ive changed the map sensor, idle air control, and throttle position sensor. Throttle position sensor has been defected out 4 times. I have tried shifting it all the way left and right and every where in between. Occasionally van just wont start and throws these codes
Old Jul 16, 2023 | 09:31 PM
You need to do some testing rather than throwing parts at it. Four TPS is ludicrous.
What is the TPS at KOEO (scan tool)?
Old Jul 17, 2023 | 12:26 AM
I changed tps and warranted it so it didn't cost me anything. I have changed the battery, battery terminals, cleaned the main ground for the battery to frame. All connections I have cleaned or changed so far have dielectric grease. I will clean all ground wire contact points, check voltage from battery to engine as ground, and positive post on fire Block to battery ground then engine ground then frame ground. I will touch base after this. Also the idle air control valve gave a code and map sensor gave a code. That's why I changed those and code has gone away since.
Old Jul 20, 2023 | 09:05 PM
I added grounds and codes went away. Van starts
liviococcia
Jan 1, 2019 11:47 AM
Rgmgpg
Dec 15, 2014 08:46 PM
forevermemorable
Aug 26, 2013 08:26 PM
ddub310
Jun 28, 2009 11:09 AM
1995 honda accord
Jan 29, 2009 12:23 AM
