2002 Odyssey transmission no reverse.
Old Feb 12, 2023 | 12:50 PM
DES's Avatar
DES
Default 2002 Odyssey transmission no reverse.
Van will move forward, seems to shift OK. When in reverse pump is fighting itself will not move backwards. Put shifter in drive and van moves forward. Each other forward gear pulls when brake is held. Trans oil is transparent with a brown/red tent and swells like it got hot not burnt.
Have remove the battery to access shift solenoids both checked good on top. Have not checked the bottom solenoid on trans yet. Screens in top solenoids are clean and test at 5 Ohms. Anyone have any thoughts on where I should look next troubleshooting? Codes that show up on code reader are PO700 Trans control system, P1750 Clutch pressure control valve malfunction. I am new at forums and threads so please bear with me.
Old Feb 12, 2023 | 01:00 PM
DES's Avatar
DES
2002 Odyssey P700 and P1750 transmission codes
Old Feb 12, 2023 | 04:23 PM
Is the light blinking?
Solenoids can be activated with 12 volts and listen for the click.
Darren Thompson
Jan 19, 2021 10:03 AM
rollone
Mar 7, 2019 01:55 AM
bruceb
Nov 24, 2010 01:35 PM
hambone5126
May 8, 2010 04:35 AM
hondamike24
Jul 5, 2009 01:12 PM
