2005 Sliding Power Doors- Next Step
Old 08-23-2014, 07:48 PM
LLCPolling's Avatar
Default 2005 Sliding Power Doors- Next Step
Hello,
We have an 05 Ex-L w RES that had been having a few door issues lately. First the driver side door started malfunctioning- three beeps and wouldn't open. Then after dealing with it on manual mode- the passenger side became increasingly touchy so we decided to repair the DS door. Replaced the rollers (middle) and it worked great until about 2 weeks later when the passenger side started squealing and making horrid noises like opening the door was the hardest thing it had ever done. Then it became impossible to open either door if the switch was in the power position- the passenger door became stuck completely- manual switch position, took incredible force to open and so we headed to the parts dept, bought new rollers for that side and replaced those too. After replacing, rehoming and nothing- then disconnecting the battery and lots of cuss words- both doors open- BUT only 3/4 of the way and not simultaneously. If you try and open them (via the master switch near steering wheel) you get three beeps followed by one continuous beep and no movement until you switch to manual. We are thinking maybe the actuator is out? Door alignment? Any help would be great. Thanks!
hanadog1
05-13-2013 08:39 AM
jstagn
02-13-2013 04:37 PM
ahsank2
04-29-2012 04:07 PM
Quick Reply: 2005 Sliding Power Doors- Next Step
