2023 navigation map update won't load in a 2011 Touring
Old Jan 5, 2024 | 10:16 AM
philwarner's Avatar
Default 2023 navigation map update won't load in a 2011 Touring
I am trying to update the navigation maps in my 2011 Honda Odyssey Touring Elite with the 2023 map database from navigation.com but when the disc 1 is inserted into the CD slot per the instructions the audio display just shows disc read and nothing else happens and the 2nd disc does the same. When I press INFO and then >OTHER as instructed by their help tech, the 4th item, "map data update status", is greyed out and can't be selected. The tech guy had no solution and sent a second set of discs which do the same thing. Now his only suggestion is to take it to a Honda Dealer.
Has anyone else been able to update the navigation maps in a 2011 Odyssey to the 2023 data base version or have any suggestions on how to get it done?
Old Jan 5, 2024 | 02:44 PM
Might need to upgrade the unit.
Old Jan 6, 2024 | 10:52 AM
philwarner's Avatar
Thanks for the reply. What unit do you mean. The CD player? It works fine to play and record CDs to the hard drive. I am not aware of any way to “upgrade” the CD unit. Or do you think I need a newer Odyssey ? (Kidding, of course).
Old Jan 6, 2024 | 09:28 PM
New NAV unit or upgrade yours.
Old Jan 18, 2024 | 08:53 AM
philwarner's Avatar
I've never heard of an update to the Nav unit. Any TSBs on this? Hondanavi says they sent the correct discs for my current map database. I asked if there was an older map update version I could try and they said it was 2023 or nothing. I gave up after the third set of discs did not work and asked for an refund.
Today I received a refund on my credit card of $86.11 which is $26.11 short of the $112.22 I paid for the map update discs that would not work, so I am out of pocket for money spent plus the hours of time I spent trying to install this map update scam from Honda.
Has anyone with a 2011 Ody been able to update their map database?
Just Ducky
Jul 22, 2024 05:54 AM
ysrinu
Dec 28, 2021 09:06 AM
wagfam10
Oct 14, 2019 09:21 AM
Steve Agostino
Jul 13, 2017 10:42 AM
