Installing a splined rear shock bolt
Old Nov 15, 2019 | 11:05 PM
Brian Peterson's Avatar
Default Installing a splined rear shock bolt
Hi Guys,
I'm replacing a rear shock absorber on our 2004 Odyssey. The lower bolt on the passenger rear shock needed to be replaced, so I applied heat and hammered the thing out. Now I have the new one and I just can't hammer the new one back in all the way. I've tried heating the area with a torch for about 10 min. and it budged about 1/4" but that's all. Am I doing this right? I can't think of another way. If anyone has some advice I'd appreciate it. Perhaps I need to keep the heat on the thing longer?
Old Nov 17, 2019 | 05:38 AM
Well I figured it out. Like often times the solution is easier than a person might think. I added about a dozen washers under the nut and cranked it down... this sucked up the stud to seat how it should be. Then I could finally install the shock.
Old Nov 17, 2019 | 10:10 PM
welcome to the forum. good job well done.
Calvin Wong
Jun 15, 2018 03:12 AM
kristin.barlow@gmail.com
Aug 13, 2016 08:54 AM
CRiSS
Jul 17, 2012 12:42 PM
john917v
Oct 1, 2010 10:25 PM
adamtb1977
Jun 25, 2008 10:52 AM
