When to rotate tires/Alignment
Old Oct 12, 2012 | 08:24 AM
HondaDad's Avatar
Default When to rotate tires/Alignment
I took my 2011 Odyssey in for service. I asked for an oil change and tire rotation. I also had them check out a clicking noise when you turn at slower speeds.
The tech said I didn't need a rotation because the front tires had more tread than the rear. How is that possible? Wouldn't you want to rotate them anyways? And why would you suggest alignment if the tires aren't wearing unevenly?
Old Oct 25, 2012 | 07:41 AM
welcome to the forum. Tires are generally rotated each 5k miles. Alighnment is done 1x a year. ( Honda does not do an alighnment out of the factory.) Also new theory on tires is the newer tires with more thread should be put in the back and the older worn tire should be placed on the front. This is due to the front has steering control and the rear has no steering on a blow out/bald tire. Per most tire shops.
Old Oct 25, 2012 | 10:44 PM
lowlife9's Avatar
you mean the worn tires should go in the back and the good tires in the front.
Old Oct 26, 2012 | 09:25 AM
no. as stated previous
Old Oct 28, 2012 | 08:11 PM
lowlife9's Avatar
so your saying that worn tires are safer in the front because there less likely to blow out that makes absolutely no sense. first worn tires equal no tred so no grip especially in the rain. worn tredless tires are more susceptible to blow outs so putting worn tires in the front on a front wheel drive car is plain dumb.
Old Oct 29, 2012 | 07:39 PM
HondaDad's Avatar
They have 20,000 miles on them. They are in pretty good shape over all.
popomama
Nov 22, 2018 08:25 AM
btle29
Feb 15, 2010 08:51 PM
94D16Z6
Nov 16, 2007 10:49 AM
locogato
Oct 28, 2007 04:49 AM
davejurek
Jul 10, 2007 06:13 AM
