Other Honda Cars and Trucks Don't see your vehicle listed above yet? This is the place for your information.
2001 Honda passport
Old Feb 27, 2017 | 07:55 PM
Carson Logwood's Avatar
Default 2001 Honda passport
So my passport recently ran out of gas and sat for 2 months before I finally got around to working on it, I got it to start by turning the motor over and holding the gas a little bit but once I shut it off, it won't start back up until a few hours later. While it runs the idle is high like a car usually does during a cold start but after it warms up the idle drops and drops all the way down to 300 rpm and then it shuts off, I've replaced the fuel filter and ran a fuel pressure test which measured 40psi with KOEO (Key on engine off) and while it ran it measured 40 psi but once the rpm dropped below 800, the gauge needle started to shake with the rest of the car and it dies.
Old Mar 1, 2017 | 03:53 AM
check/clean the ICO.
Old Mar 1, 2017 | 10:43 AM
I don't know what you mean by "ICO"
Old Mar 2, 2017 | 03:52 AM
Idle cut off. will cause idle to go high on cold start, to start and die, or low idle below 800rpm. if you have over 100k miles sometimes a valve adjustment will cause the same.
Carson Logwood
Jan 24, 2017 04:13 PM
Carson Logwood
Jan 16, 2017 09:02 AM
Carnage_7
May 9, 2008 03:46 PM
atikovi
Nov 7, 2006 09:26 AM
jack_spicer
Aug 18, 2006 12:46 PM
