Other Honda Cars and Trucks Don't see your vehicle listed above yet? This is the place for your information.
DC5 Integra SRS Light On – Codes 07-2 & 12-3 – Need Help Diagnosing
Old Apr 18, 2026 | 02:09 AM
ROGE2692's Avatar
Default DC5 Integra SRS Light On – Codes 07-2 & 12-3 – Need Help Diagnosing
Hi all,
I’m trying to get my Honda Integra DC5 (base luxury) roadworthy in Victoria and I’m stuck on an SRS light issue.
Problem
· SRS light is constantly on (solid, no flashing)
· Car has no known accident history
Codes
· 07-2: Internal failure of SRS unit
· 12-3: Side airbag failure (passenger side)
From what I understand, 07-2 is likely secondary to 12-3, not necessarily a failed SRS module.
What I’ve Done So Far
· Cleared codes → they come back immediately (light stays on as soon as car is on, no blinking/flashing)
· Checked and reseated yellow connector under passenger seat (side airbag)
· No visible damage or corrosion in connectors
· Tried using a resistor (~2–3Ω) in the passenger seat connector (vehicle side) → Code still remains
· Disconnected driver side airbag → new code appears as expected → suggests SRS unit is responding correctly
Current Understanding
Based on this, I believe:
· Seat airbag module is likely OK
· Issue is likely wiring between SRS unit and passenger seat (floor harness)
· Possibly an open circuit or high resistance somewhere in that loom
Where I’m At Now
I’ve removed the centre console and located what I believe is the SRS unit and connectors
I’m trying to follow the service manual which says to:
Check resistance between Pin 7 (WHT/RED) and Pin 18 (WHT/GRN) on connector A (18P)
However, the connectors I’m seeing don’t match the diagram in the manual, so I’m not confident I’m probing the correct pins.
What I Need Help With
1. Has anyone had a 12-3 code on a DC5 and found the fault in the floor harness?
2. Can someone confirm the exact location of Connector A (18P) on the SRS unit or provide a photo of the correct plug/pinout?
3. Any common failure points in the wiring loom between seat and SRS unit?
4. Is there anything else I should check before assuming wiring issue?
Goal
Just trying to get the SRS light off for roadworthy, not looking to overcomplicate it.
Any help would be massively appreciated — I’m starting to hit the limits of my electrical knowledge.
Thanks!
Honda48
May 27, 2018 10:09 PM
NHKen1
Oct 5, 2010 12:36 PM
paulpatter
Sep 1, 2009 06:38 AM
caverspencer
Nov 12, 2007 05:25 PM
KCChiefs9690
Nov 18, 2006 03:09 AM
