2020 Pilot EX-L noise on the back
Old Aug 28, 2020 | 08:35 PM
Honda_Simon's Avatar
Default 2020 Pilot EX-L noise on the back
Hello all. I hear some kind of noise/sound on the back while driving through the bumps. Does anyone have such an issue as well? Drove 400 mi so far
Old Sep 1, 2020 | 11:19 PM
welcome to the forum.. we had a noise in the back on our 2016 hr-v. took it in a few times, found the rear stabilizer bolt to be loose. we documented when the noise came, bumps, driving up and down a drive way with a mild grade, how often took about 3 days to find it. left the HR-V at the shop for the techs to find it. no noise after the fix. no charge.
Old Sep 6, 2020 | 08:47 AM
I had dealership checked the car and they couldn’t find anything. I also took another Pilot (2021 in this case) for a test drive. It was a bit quieter but I got same bumpy noise reproduced as well. I am assuming all the Pilots have it. Maybe I will try to check it one more time at another place.
Old Sep 7, 2020 | 09:35 AM
Welcome in,i had a problem similar on a vehicle years ago. After determining it was the suspension i got under it with a set of sockets and tightened every nut i could find ,it turned out to be a torsion bar. Good luck on your quest.
Tie Zheng
Jan 28, 2020 01:26 AM
RoadRnr
Aug 18, 2018 10:31 PM
BlueEagle21
Aug 13, 2018 04:51 PM
bfmgoalie
Sep 24, 2016 05:19 PM
rnidler
Mar 6, 2010 02:34 AM
