Prelude Forum This sporty coupe was popular with anyone who wanted a sporty, economical ride.
98 "si" idle issue
Old Apr 26, 2011 | 08:09 PM
r0b369's Avatar
Default 98 "si" idle issue
we have a 98 "si" with a 22va, when it warms up it will stall at idle all the time. local shop couldnt figure it out. dealr (autofair in manchester nh) said it was a "recall" item and bring it in. changed ignition switch and told my wife it needed a bunch of things it didnt need . still stalls at idle . a friend "cleared" the code light and it ran good for a few hours ,then back to the same. any thoughts? rob
Old May 5, 2011 | 06:18 AM
ChaseMark's Avatar
Changing the air filter may help....complete combustion is probably not taking place cos not enough air is getting into it....If idle speed rpm is lower than it should be...you might want to try making it higher...
Old May 13, 2011 | 02:34 PM
What codes did it throw,you may want to clean the throttle body to start and check o2 sensors.
Old Jan 23, 2012 | 09:05 AM
Donkeydawn11's Avatar
Default stalling
I just had a similar problem my car at start up (cold) it would run for about 3 secs and cut off after 7 x it would run and the rpms would go up and down for a while before going to normal I had the car in the shop and they said they replaced a main relay located under the dash. I dont know exactly what relay they were speaking of but there is a relay that when broken it will give you a no start situation. So I guess one thats on its way out could give you stalls as well. hope this helps you.
Old Jan 24, 2012 | 07:48 AM
So does it idle correctly now?
bcole6
Apr 30, 2013 09:30 AM
dinz334
May 17, 2010 05:28 PM
marwataymour
Feb 10, 2010 04:39 AM
emmyloulou
Aug 6, 2009 03:29 AM
djletin
May 24, 2009 08:58 PM
