Prelude Forum This sporty coupe was popular with anyone who wanted a sporty, economical ride.
HELP PLEASE! Car keeps shutting down while driving!
Old Oct 9, 2009 | 12:18 PM
hanguksimon's Avatar
Default HELP PLEASE! Car keeps shutting down while driving!
Hi, I recently started having a problem with my engine shutting down on my 92 lude Si, its got about 220000 miles on the body but the engine was rebuilt due to accident. It first happened a week ago right after I filled up gas, I went to turn the ignition and it just died, not cranking, no sound, just completely shutdown, and the lights wouldn't turn on or anything. As if battery was completely dead. My buddy jumped me and I was good to go. Couple days later, it shut down on my while i was driving, I think I was in second gear slowly accelerating, and I couldn't crank it over for a few minutes. Then it was fine. Then next day same problem, much more frequent, every 10 to 15 minutes it would shut down while driving and the check engine light comes on and shuts off. It would crank but not start until a few times cranking and hitting gas, and once it starts, check engine light dissappears until it shuts down again. Any suggestions? I am going to clean battery terminals, check voltage on the battery, voltage on alternator. Any help would be great! Thanks!
Old Oct 10, 2009 | 02:27 AM
welcome to the forum. Check your ignition switch, (heavy key ring) or worn out.
Old Oct 11, 2009 | 09:49 AM
Cool, thanks! I'll give it a try!
Old Oct 17, 2009 | 02:11 PM
Ok, sorry for taking so long to reply, I have replace my batter terminals because they were badly corroded, and I have gotten my battery and alternator tested, and both are fine. Now when the vehicle stalls, the power doesn't shut off, just dies and check engine light comes on and it takes a few cranks with me furiously hitting the gas simultaneously, are these signs of fuel pump to injectors?
Old Oct 20, 2009 | 02:09 PM
check the ignition coil, main realy, and fuel pump pressure at the fuel rail. When warm, or car engine warm, and no start normally main relay.
Old Nov 7, 2009 | 03:15 PM
Ok everyone, so sorry I have lagged this long again to post results, been super busy, well, I broke down and took the ride to the mechanic, and after everything, it was the distributor, it was done, got a new one, running like a champ again, thanks for all the help everyone!
Old Nov 9, 2009 | 02:42 AM
88dblifestyle's Avatar
Yeah, i agree dude. You can also check your battery, sometimes battery does.
CRiSS
Oct 18, 2012 06:24 PM
kevin_405
Jun 18, 2012 07:09 AM
qdog1965
Mar 13, 2011 01:17 PM
Silverbullett
Jan 17, 2011 06:01 PM
rufryder
Feb 6, 2010 02:31 AM
