17' Ridgeline keyless ignition batteries
Old Jul 28, 2019 | 01:14 PM
menzies's Avatar
Default 17' Ridgeline keyless ignition batteries
I had a message on the dash that the key-less ignition battery was low. I found a you-tube video on how too change the battery and also what size too use. I fitted a new 2032 battery and it would not work. I took the battery from the spare that had been hanging up and it worked until today when I got another message low battery. I fitted a new battery in the the spare and it also will not work. I did buy another couple of new 2032's and they will not work.
Am I missing something here like wrong size batteries. I could find nothing in the owners manual about changing the batteries just how to use the key-less apparatus.
Any guidance is greatly appreciated.
Old Jul 28, 2019 | 04:23 PM
Were the new batteries put in correctly??
The battery does have a polarity.
Check battery voltage level
Also, some key fobs need proper alignment when putting the two halves back together or they will not work
14Clarity
Dec 7, 2018 04:31 PM
misterix
Oct 6, 2011 10:54 AM
akaiheart
Aug 15, 2009 10:29 PM
lbrown`
Jun 3, 2007 09:31 PM
ol9finger
May 2, 2007 06:36 AM
