Help with braking
Old Jul 1, 2019 | 07:03 PM
David Kidd's Avatar
Default Help with braking
I have a issue with my abs light and vss system kicking on and the brakes dragging. I have taken it to my mechanic and we put two new cabilers on the left side as well as a brand new master cylinder we followed all thehonda protocols while doing this and I'm still having a issue with the abs light and stuff kicking on its on a 2007 Honda ridgeline hope to get some possible leads pedal seems to be good
Old Jul 1, 2019 | 11:42 PM
I have never done diagnosis of ABS systems
But, my thinking is that the ABS uses a wheel speed sensor to determine when to apply the ABS system
Since you have already replaced the caliper and master cylinder, what else is left???
Old Jul 2, 2019 | 12:24 AM
welcome to the forum. your ABS control module may be failing. brakes dragging, abs light on. also sensors may be going bad.
Old Jul 2, 2019 | 05:53 AM
David Kidd's Avatar
When all the lights came out i wasn't a hilly Rd also
nikes_ny
May 20, 2007 02:29 AM
nikes_ny
May 2, 2007 12:58 AM
nikes_ny
May 1, 2007 12:59 AM
proff
Feb 12, 2007 01:00 AM
DadDog83
Nov 26, 2006 09:53 PM
