honda foreman 450es braking problems
when i apply my front brakes my front right tire, (wheel) locks up. I backed off the adjustments but it still locks up the front right tire not as bad but still does. It never did this before any suggestions?
Aloha roses 15534 check your caliper guide tubes. if they get dirty or sticky, when you release the brake, it may cause the pads from returning or freeing the disk. Using brake cleaner may help. don't spray anything on the pad or disks. And welcome to the forum. Would you have a service manual of some kind. If you go to majestichonda.com you will find the picture of the guide so you can see what to clean off.
nasir01
Apr 9, 2014 10:21 AM
