1 gen CRV radiator fan won’t come on
Old Apr 20, 2026 | 04:00 PM
grantlyn513's Avatar
Default 1 gen CRV radiator fan won’t come on
Aloha,
1st, thanks for any help, as this one has me stumped. I have a 1998 Honda Crv and the radiator fan doesn’t come on unless you turn on the AC, where then both the radiator and AC fan come on together.
i found a bad relay, when I switched my radiator fan relay and AC fan relay. So I swapped it for a new one and still it wouldn’t come on.
and yes, I would wait about 5 mins for the car to heat up to check if the radiator fan would come on, but it wouldn’t.
I assumed the engine coolant temp sensor went bad so I installed a new one, but still doesn’t run the radiator fan without the AC on.
I am thinking the fan switch could be bad, but I am a bit lost now.
got any ideas? Please help
Old Apr 20, 2026 | 08:05 PM
With a scan tool.Check the ECT and see if it's just not getting hot enough.
Old Apr 21, 2026 | 07:58 AM
By scan tool, do you mean OBD 2 reader? And I did just replace the coolant temp sensor, but is that different from the ETC?
Old Apr 22, 2026 | 07:38 PM
We need to see what the PCM sees. Could be it's not getting hot enough to request the fan.
Old Apr 23, 2026 | 04:36 AM
Sorry my code reader does say that data :/
Old Apr 30, 2026 | 02:36 AM
matu253's Avatar
Temperature switch PINs need to be twisted a bit. This era had problem with loose connections in plugs
Old May 1, 2026 | 05:56 PM
Have you found this a problem and actually twisted the pins? The best way to fix loose connections is to squeeze the flat on the female. Twisting pins often breaks them.
Old May 5, 2026 | 04:12 AM
matu253's Avatar
Thumbs up
did on my car with NEW switch because it did not fuction. This method is best way cuz if you brake the other plug end then you need rewire from car side. Yeah, twist them jus ta bit
Dairo Abayomi
Apr 22, 2026 07:05 AM
cmgreg
Dec 1, 2020 02:50 PM
clkinaz
Oct 30, 2020 02:37 PM
Dairo Abayomi
Aug 23, 2020 01:00 PM
CRockerDad
Sep 21, 2012 01:36 PM
