2002 CR-V Code: P0341
Old 03-11-2021 | 05:22 PM
JMBB's Avatar
Default 2002 CR-V Code: P0341
Poor student needs HELP: 2002 CR-V - 300,000 km, ALWAYS synthetic, every 5,000 km (Excessive, I know).
Suddenly running rough and missing. CR-V threw a P0341 code.
This comes after I cleaned out the IMRC, replaced the runner control valve, and an ignition coil. I suspected timing, so I had a mechanic take over from here; I've done a few chains and I now live on a boat, so no space for that kind of job in a parking lot.
Timing skip confirmed: mechanic replaced timing chain, sprockets, tensioners, water pump, crank seal, serp belt.
Still throwing P0341 code.
Replaced cam sensor.
We are kind of stuck now, and I don't want to replace sensors *****-nilly. Has anyone here had a similar experience? I am thinking about ordering this:
https://www.amazon.ca/Solenoid-Pressure-15810-RAA-A03-15810-PNE-G01-15810-PPA-A01/dp/B085PS89JC/ref=sr_1_1_sspa?dchild=1&keywords=crv+vtec&qid=1615496534&s=automotive&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFVVTZQODhRS1UxTTYmZW5jcnlwdGVkSWQ9QTAyNTE4MzEzRTJXT1E0N1I1NE9VJmVuY3J5cHRlZEFkSWQ9QTA5MTIyMTIzVUo5QTFUMU02TVhDJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== https://www.amazon.ca/Solenoid-Pressure-15810-RAA-A03-15810-PNE-G01-15810-PPA-A01/dp/B085PS89JC/ref=sr_1_1_sspa?dchild=1&keywords=crv+vtec&qid=1615496534&s=automotive&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFVVTZQODhRS1UxTTYmZW5jcnlwdGVkSWQ9QTAyNTE4MzEzRTJXT1E0N1I1NE9VJmVuY3J5cHRlZEFkSWQ9QTA5MTIyMTIzVUo5QTFUMU02TVhDJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
This is my first time posting here, and any help is really appreciated.
Thank you
Old 03-11-2021 | 09:47 PM
welcome to the forum. some of the items listed have been done. crankshaft position sensor harness has an open or shorted. crankshaft position sensor poor electrical connection. faulty starter motor. check for damaged components, lok for broken bent, pushed out pins.
StManson
12-15-2020 12:07 AM
rh2078
05-14-2020 11:44 PM
Podenco
04-07-2016 02:16 PM
C Check
10-09-2009 10:49 AM
